Sei-Mad
Member
[Right rant mode starting now..]
How it all started, back in Dec 2003 I was stuck in traffic, yippee, cooling system heated up, fan kicked in and the car overheated. At the weekend after this happened I had to replace the fan and the "motor" failed and rusted away. So Brought another one from the scrap it works as I've tested it with a fused feed from the battery.
Right, all is okay - not. For some reason, I get to overheat the car and the fan will not kick in. Pull the plug out of the rad (899 cc, green connecter in the rad) and bypassed this with a paperclip - nothing, fan will not work. Check fuse (from drivers side fuse box) with multimeter and fuse is okay. Striped side plastic to check power supply. reading is 0v with the bypass paperclip or plugged back into the rad. So the power is not getting there.
What am I doing wrong? Is there something else i've missed???? Is there another switch or fuse gone bust?
(Note, I have seen something behind the battery that say 30amp and a fan shape on it - is this another fuse for the fan, but I can't access it.)
HELP!!!!
[end rant]
Mike
Shopping List:
-40mm Lowing Springs
Cadamuro Rear Spoiler
Window Tints
Scrapped 1.2 Punto
HELP!!!!
[end rant]
Mike
Shopping List:
Window Tints
Scrapped 1.2 Punto
