Old 05-04-2007   #1
Trader Rating: 3
gazzaman2k has donated!
Decomp plate which side do i stick it to the engine?
Decomp plate which side do i stick it to the engine? does it go onto the head side or the block side?
also anyone know thepart number for the core plug bung thing thats about 2" disc that goes on the side of the block as mine has heavily corroded which would explain the dripping water out of the gearbox side.
cheers
gaz
Project Seicento
gazzaman2k is offline Reply With Quote Quote
Old 05-04-2007   #2
Trader Rating: 5
fingers99 has donated!
Re: Decomp plate which side do i stick it to the engine?
Use it like a normal head gasket (so, that's block side) but put hylomar on it both sides. You don't really stick it.
No idea of the part number of the core plug.
fingers99 is offline Reply With Quote Quote
Old 09-04-2007   #3
hi friends :waves:
Liam's Avatar
Liam has donated!
PN should be 14329201
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 13-04-2007   #4
Trader Rating: 2
davethetrike has donated!
Quote Originally Posted by fingers99 View Post
Noooooo, decomp goes onto the head, the head gasket goes onto the block.
The Proton coupe, Evo's lovechild.
davethetrike is offline Reply With Quote Quote
Old 13-04-2007   #5
Trader Rating: 3
gah ahwell it should still run
Project Seicento
Old 13-04-2007   #6
Winning
GhostWKD's Avatar
GhostWKD has donated!
yeah what dave said decomp plate should be hylomar'd to the head then just use HG between decomp plate and block
GhostWKD is offline Reply With Quote Quote
Old 14-04-2007   #7
kritip's Avatar
Trader Rating: 4
kritip has donated!
Quote Originally Posted by gazzaman2k View Post
REmeber to take this into account when calculating your CR though, it would be slightly higher with the gasket in.
Also the block surface should really be machined if fitting a metal gasket, so I'd imagine its even more important without a gasket.
If you haven't got too far I'd stick it back in...thats just my opinion though. Be a pain if it fails straight way!
OT: why not fit two gaskets either side and lower the CR even more?
Kristian
kritip is offline Reply With Quote Quote
Old 14-04-2007   #8
Italy
I have heard it on good authority from a few friends that a decomp plate messes with the squish band, which in doing so creates a poor mix and less power than an engine should be making.
Low comp pistons are really far more ideal for long term use, but if you do use decomp plate for short term I would just make sure its sealed up professionally and you have calculated the cr precisely correct (as above basically!)
J.R Racing is offline Reply With Quote Quote
(T) tempra engine valves problem kostik4u Tempra 1 31-01-2012 13:44
(T) Engine Fault Light - Drives OK Please Help fonetech Stilo 12 09-01-2007 22:51
(T) Knock Sensor? arseofbox Bravo / Brava 13 29-03-2006 18:24
(T) Uno 1.0 ie. Smelly smoke and knocking noise. SilentPartner Uno 17 27-03-2006 17:00
(T) Problem.....RED Engine LED always on..... :( tubi Punto (Mk2/2b) 7 28-02-2006 12:48
