Technical P85 fuel pump into a cinquecento tank
arc
this is where i stand
Manchester
Just been down to the scrap yard to get a new fuel pump. I've got a Punto 85's fuel pump.
Pipes and connections are the same, but the design of the pump is more different than i thought it would be.
whats the easiest way to mod it so that it'd all fit. should i make a plate up that fits the cinquecento tank and then fit the punto pump into that? I'm a lil iffy around fuel systems, can cause big problems if it goes wrong!
3.5bar fuel pressure :eek: you need that much? i know when my grale was mapped from 210-250bhp the fuel pressure was raised from 2.5 to 3.2bar as the grale pump is adjustable, but this was all done with a gas analyser, just seems really high. i thought it was 2.5bar on MPi's.
Aaron.
this bit?
was tempted to try and get the whole thing swapped over as the punto pump seems to have a better gauge sender unit. oh well though!
arc said:
this bit?
yeah that bit will be the bit wont it. tis how i thought it was done when i was looking the other day. some one wanted a 75 pump off me to do it with but they turned out to be time a waster :p :D
