Thread Tools
Old 15-12-2011   #1
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Exclamation A quick winter wash (Tips..)
Lets face it its cold damp and horrid out there and no one in their right mind is going to want to spend hours outside cleaning the car only for it to be as bad again the next time you go out not everyone has a pressure washer so this wash is been done without one...........
Obviously at this time of year they start lathering the road with rock salt which coats the car obviously this is no good left on the car and is better rinsed off as often as possible That and it keeps your lights number plate and windows clear.....
so start with a dirty car...
I always start with some kind detergent pre-wash this could be either applied by a hose dispenser such as a Gilmour
a Super-Spray
or even a pump up garden sprayer
even a watering can will do
I just use a cheap car shampoo im currently using Turtle wax big orange which is on offer in B&Q at 5 (or it was when i got some)
http://www.diy.com/nav/build/motorin...LAID=793778137
I use a metric "Glug" in the gilmour and top up with water the dirtier the car the more i put in .......
Next i start low down and cover the car working upwards in the solution and leave to soak for a few minutes
(whilst its soaking i refill the bottle and Fill a bucket with clean water and rinse the wheel arches out)
Next step is to rinse the car well with a fan jet of water to remove the worst of the soiling
So you now have a wet and slightly less dirty car
(notice that i didn't pre rinse the car with water this allows the shampoo to soak in and not be diluted any more by water still on the car)
As i said earlier i filled a bucket and refilled the soap dispenser
Rinse the wash mitt out thoroughly
and load it up with a blast of solution from your sprayer
then apply car shampoo to a section of the car eg the roof
then lightly wipe over with the wash mitt to remove the film of dirt
Then rinse the mitt out in the bucket and do another section leaving the dirty lower sections until last......
and use a separate wash mitt/ brush on the wheels
Once all been lathered up start to rinse from the top down using a flowing hose and "sheet" the water off the car.. (this works best on a waxed car) and in doing so it is possible to get the car 95% dry using water.............
let the car drip dry for a few minutes
then
Go over with a microfibre Drying towel or if you prefer a chamois
and there you go a clean car with minimal risk of scratching or swirling your paintwork
Thanks AgnessGP, RobinPJ thanked for this post
Massive gash
Just a little touch up
Old 16-12-2011   #2
Moderator
dombooth is part of the official FF Events Team :)
dombooth has donated!
dombooth is an honorary friend of the forum :)
DiffSpotter 3 - Rooms Champion
Re: A quick winter wash (Tips..)
I'll be round in the morning.
Only joking lol.
I pulled into the Polish car wash then thought better and exited quickly lol.
Dom
Current Car: FIAT Bravo 150T Sport
And the mighty Fiat 126!
dombooth is offline Reply With Quote Quote
Old 16-12-2011   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
they use the same mit all day and the same big bucket of water in my 2 local ones
I avoid like the plague! but parents insist its okay
There cars are really swirly, mine aint!
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 16-12-2011   #4
Moderator
Quote Originally Posted by Ziggy122 View Post
Ziggy
I know it's just that it's so cold lol.
I'll do it on Sunday, if doesn't snow as I get half way through again.
Dom
Old 17-12-2011   #5
Moderator
Andy Monty's Avatar
Man up dom ;-) its only cold when the water freezes on the car as you wash it.......
Old 17-12-2011   #6
Moderator
Quote Originally Posted by Andy Monty View Post
I did two wheels and called it a day.
Dom
Old 17-12-2011   #7
Moderator
Andy Monty's Avatar
washed and applied jett on mine on thursday....
Had to wash it last night as had to drive across a compacted mud field to get out of work yesterday,
then Did sisters 500 and gave it a coat of Jet and gave mine a quick wash Since i went out for a meal last night those mud flaps dont like 4 big lads up think they are a few inches shorter now ... and Polished a scratch out of dads wing.......
Its not that cold
Massive gash
Old 17-12-2011   #8
Moderator
Its not that cold
It's bloody freezing here! lol
Dom
Old 22-12-2011   #9
Canada
Only suggestions I would make are to try to use warm water (NOT HOT) as it will dissolve the soap better and do a better rinse. Also a chamois will strip off wax as you try to get the last bits or rinse water off the painted surfaces; the micro towel is much better. Be sure to dry the door jambs or the doors may freeze shut if left out overnight in freezing weather.
Be sure to rinse the undercarriage because the mag chloride used to melt road ice should be rinsed off at least weekly.
fiat500prestopresto is offline Reply With Quote Quote
Old 23-12-2011   #10
Moderator
Andy Monty's Avatar
A chamois wont strip off wax as its chemically bonded to the clearcoat/ paint i use a MF DoDo supernatual Drying towel personally, But this was intended as a guide for those not into detailing and just want a clean car
The chance with a chamois is the large flat surface of the leather can if the car is not 100% clean any dirt will be dragged across the surface of the paint inflicting scratches or Micromaring.
For cleaning the underside i use a lawn sprinkler when its too cold and horrid to crawl round on the driveway with the pressure washer
Massive gash
Old 07-09-2013   #11
Trader Rating: 10
dave has donated!
this big orange better be good, i didn't take glasses so didn't realise until i got home you have to add 4 cap full to a bucket, that is a massive 80ml does it know my buckets are 10-15 litres or will i need to double or triple the 4 cap full?
B&Q had a 3 for 2 on too so i had to buy more stuff even though i only went in for shampoo i couldn't miss out on a deal. I got rainx anti-fog as ive always wanted to try it, also got turtle wax platinum series leather cleaner & conditioner instead of Autoglym Leather Care Balm as that didnt say on the front that it cleaned too, couldnt read the back so was unsure if it needed the cleaner separate?
Old 07-09-2013   #12
Is that orange bug wash any good to stick in a foam lance then?
Ziggy
Meet Bumble-Bee
Old 08-09-2013   #13
Moderator
Andy Monty's Avatar
Quote Originally Posted by dave View Post
Its the cost of one local imegrant hand car wash here .. it makes bubbles it cleans rather well even I cant see the point in using really fancy boutique car shampoos in winter
http://www.detailingworld.co.uk/foru...ad.php?t=33955
http://www.detailingworld.co.uk/foru...ad.php?t=82450
Ziggy
not really a foaming cleaner this guide was intended for those who dont have access to a pressure washer
Massive gash
Old 08-09-2013   #14
Trader Rating: 10
dave has donated!
I've searched on the turtle wax websites and still cant find out what size bucket they are referring too
i seen you mention big orange in a few threads chose this one as it will be winter again soon pissing down with rain now so no washing is being done
Old 08-09-2013   #15
Moderator
Andy Monty's Avatar
i just put a glug in a bucket cba measuring stuff like shampoo fair enough strong trade stuff such as G101 needs a bit of care but retail car shampoo meh
Massive gash
Thread Tools
Quick Question-Basic Wash micsy Car Care 9 25-02-2009 19:57
(G) Anyone looking for a quick way to wash their baby? roadster1_98 500 7 25-05-2008 22:35
Mums Corsa Quick wash with a foam gun. Ant1974 Car Care 10 08-03-2007 21:09
(G) Brava rear wash/wipe and headlamp washers - no wash!! PhilWalker Bravo / Brava 4 30-04-2005 21:42
