General Towbar
General Towbar
Jim-Armao
Fanatic
Thessaloniki, GR
Is there anywhere any info on how to install a towbar on Bravo.
Any schematics or pictures of the mounting points on the body of the car is all I need.
you need to use the towbar bracket as a stencil to mark where holes will be drilled.
dont forget big washers either side of the bolt holes to spread the pressure.
Depends which model towbar you are fitting. They should come with destructions and if its 2nd hand most manufactures have the manuals available online.
