again its the 1.2 formula. year 2000
main problem for this thread is as title
squeeking-ish/noise when clutch not pressed from cold start
if i push the clutch down the noise goes.
i let it get warm again wouldn't like to really say but it possible slightly better. but the noise is still there
looking down at the belts the noise was deffo lower or behind to the right ish poss under the car?
could it be clutch bearing? anything to worry about?
my dads truck has dont it for about a year now thinking worn clutch baring
belts make slight noise but not too worried about them as this is a separate issue im sure and will get the belts done when its properly mot`d anyway
so can i ignore this till i need a new clutch?
