Old 09-06-2010   #1
Help! engine/injector light on dashboard
Hi!
Sorry about the lack of technical knowledge but i am new to this and need some help. The orange injector light has come up on the dashboard of my brava 51 plate 1.6 ELX. In the manual it says you can continue on your journey etc, but i can't get to a garage until the weekend to get it checked out. I travel 80miles a day to and from work, so thats 160 miles before i can get to a garage, will i be ok travelling that far without getting it checked out or should i borrow my boyfriends car till then?
Sorry for being a typical clueless girl, but i'd love some advice :-)
Ali
Alibrava is offline Reply With Quote Quote
Old 10-06-2010   #2
Coupe 20v W/Fc Chip
Bravo16VSpoonz's Avatar
Bravo16VSpoonz has donated!
Re: Help! engine/injector light on dashboard
ok, normally before you strike the car up, i leave it on the 2nd turn for 3-4secs and then start it. does the injector light come back on when the car starts? it should go off in 5 secs when the ignition is on
Coupe 20v Turbo
Bravo16VSpoonz is offline Reply With Quote Quote
Old 10-06-2010   #3
It stays on the whole time, doesn't go off at all whereas it used to be on just while turning the key and then it went off like the rest of the dash lights
Old 10-06-2010   #4
Coupe 20v W/Fc Chip
the only thing i can think of is to replace the injectors, if you say its on all the time.
Coupe 20v Turbo
Old 10-06-2010   #5
hi my bravo has had this issue since i got it, it used to be constant then i ran sum redex through with my petrol now it comes on n off as it pleases but its more off than on now
redex is mr musle for ya car if ya like avaible from tesco petrol station about 4.50 put 10 petrol in pure have bottle in n then put another 10 petrol in, repeat few days later also try not to run low on fuel in the future as this cause crap bulit up to be pulled through cloging injectors etc ope that helps if ya find the cause let us no please.
Cheezy is offline Reply With Quote Quote
Old 10-06-2010   #6
Coupe 20v W/Fc Chip
Quote Originally Posted by Cheezy View Post
good advice cheezy
Coupe 20v Turbo
Old 10-06-2010   #7
I'm no expert but if the engine management light has come on, the idea is to take it into the garage where they can read the "fault code" to see what the problem is. It could be very minor. There's plenty of debate about those redex additives but can't hurt I suppose. Drive gently, like you've got your granny aboard, until you know what's causing the light, that's the main thing.
tttom is offline Reply With Quote Quote
Old 10-06-2010   #8
Quote Originally Posted by tttom View Post
the engine managment light is a spanner shaped light and the injectors are a funny shape cant quite describe it lol but if its a spanner id seek expert advise asap but if its the other try redex and c wat happens nothing to major proberbly jus be a clogging sum wer, seek a garages opinion if unsure but id defo give redex ago if noticed a improvement in general since i have done it and i will repeat every couple of months jus to keep it running through smoothly as i tend to run low on fuel often i no i shunt do this but times are hard lol .
Old 10-06-2010   #9
Quote Quote:
That's intriguing. I think my mgmt light is combined with the injection light (a petrol pump nozzle logo). I read that this pump logo was replaced with an engine logo on later models but that spanner logo you describe does sound familiar, though I don't think I've got one of those. I must go and look at the book...
Old 10-06-2010   #10
this might be possible but on mine i can c the outline of the spanner aybe its worth jus having a look. i havent got a rev counter in myn which is pants lol 98 model
Old 11-06-2010   #11
Coupe 20v W/Fc Chip
hey cheezy, isnt yours a 1.4 ? in my 1.6 i have the injector light instead, i dont believe i have a spanner
Coupe 20v Turbo
Old 11-06-2010   #12
Quote Quote:
This is great news. Mine's a 98 also (but an sx), and with its own problems (see other thread about the sticky throttle switch) so I'll be very heartened if it turns out I've got a spanner logo that's never needed to show itself! I'm off out to have a search with the torch now..
Old 11-06-2010   #13
Turns out there's no spanner logo on my one. There are some logos which are present on the dashboard but have no lights installed behind them (e.g. the wee coil for diesel models). I suppose the same dash unit is shared by different models.
They did a wee redesign midway through 98. I remember cos I once bought a petrol cap that was for the wrong half of the year. The spanner must've been in the newer (?) version I reckon.
Old 11-06-2010   #14
Speedbump grimacer
Adrian Bravo's Avatar
Trader Rating: 1
Adrian Bravo has donated!
The injector light is the ECU error light on these cars. If the light shows it means the ECU has detected an error, error codes can be read from the ECu.
Adrian Bravo is offline Reply With Quote Quote
Old 03-03-2011   #15
Ireland
dont suppose this is the engine light on a 97 cinquecento aswel?
craigk is offline Reply With Quote Quote
(G) Injector/engine light? mrssnow Bravo / Brava 5 19-08-2009 20:00
(G) Key code light DOES NOT COME ON, injector light on. Engine turns but does not start. bravovarb Bravo / Brava 8 19-08-2008 13:38
(T) Injector light ON and engine dies - help!! philipreji Uno 2 31-10-2007 20:34
(T) new engine injector light stays on phil25196709 Punto (Mk2/2b) 4 03-07-2007 14:12
(T) Engine Revs Itself And Injector Light Is On connaco Bravo / Brava 0 13-05-2006 14:40
