Thread Tools
Old 21-01-2009   #1
Speedbump grimacer
Adrian Bravo's Avatar
Trader Rating: 1
Adrian Bravo has donated!
Fiat Bravo Spoiler for 1.99
For 1.99 I couldnt resist buying a spoiler for my Bravo
The Spoiler has PN:716152000 and a date range grid 95-99 but its not stamped I can not find it on eper so guess PN changed to 716152099 at some point.
I do not have all the nuts and stuff so I may have to buy them.
I suppose I will get this, my blistering rear bumper and a replacement front wing sprayed up at the body shop.
Need 1x Boot Glass with holes 7798966
Need 4x NUT 7767163
Need 4x PLANE WASHER 12647707
Need 2x RESILIENT BUSH 46449343
Anyone know if these bolts unscrew or just pull out? The outer two are missing.
Adrian Bravo is offline Reply With Quote Quote
Old 21-01-2009   #2
faster! FASTER!!!
bulldog5046's Avatar
Trader Rating: 2
bulldog5046 has donated!
Re: Fiat Bravo Spoiler for 1.99
bond it on rather than trying to get tailgate glass etc
Thanks Adrian Bravo thanked for this post
Ex Marea Turbo GTi-R owner & BMW Z4 3.0
bulldog5046 is offline Reply With Quote Quote
Old 21-01-2009   #3
Speedbump grimacer
Trader Rating: 1
I have a fear of it falling off would tiger seal for example hold it tight with a blob on each of the 4 holes?
Old 22-01-2009   #4
fiat_-_bravo has donated!
Quote Originally Posted by Adrian Bravo View Post
Got myn off Ebay. I ground the studs off and used tiger seal to glue it on with. That was nearly 3 years ago and it still not moved.
I put a blob were the studs were and on the inner edges of the spoiler.
Honestly mate I thought the same as you that the tiger seal wouldnt hold it but honestly my spoiler is going no where
fiat_-_bravo is offline Reply With Quote Quote
Old 22-01-2009   #5
Speedbump grimacer
Trader Rating: 1
Quote Originally Posted by fiat_-_bravo View Post
Cool ill go for tiger seal then cheapest option by far.
Did you get it in place and hold it with tape or something?
And did you put tiger seal along the top edge where the rubber bit runs?
Old 22-01-2009   #6
Yeah I offered it to the car once I was happy with the possition i taped it in place to hold it. iirc i think it takes 24 hrs to cure.
Yes I applied the tiger seal along where the rubber strip is. Use plenty of making tape because i got a bit on the paint work and although it didn't damage the paint it took a good 12 months to get it off.
This tiger seal is brilliant. Even when i was tiling the kitchen a few months back, the tiles are quite large I used tile adhesive and the tiles were to heavy and dropped off. So i tiger sealed the tiles to the wall and they have not moved
Old 22-01-2009   #7
Speedbump grimacer
Trader Rating: 1
Im a little worried about it taking the paint off. plus id rather bolt it so i can still take it off when i want to polish the car/spoiler.
Though tigerseal is going to be the only cheap option.
Old 22-01-2009   #8
What do you need to remove it for?
If it was bolted the the glass you would have to remove all the trim around the inside of the hatch to un bolt, and its a lot of hassle just to clean the car.
Old 22-01-2009   #9
Speedbump grimacer
Trader Rating: 1
Im just a big kid i like things that you can dismantle. Your right though ill just tigerseal it on
Old 22-01-2009   #10
I think I have got the nuts and gromits that were on myn still. I will check tonight.
If you go down the bolting it on root pm me with your address and I'll post them to you.
I will let you know tonight if I have still got them.
Old 22-01-2009   #11
Speedbump grimacer
Trader Rating: 1
Fantastic that would be ace
Old 22-01-2009   #12
Get busy livin'
klemster's Avatar
klemster has donated!
Ireland
put adhesive any where the spoiler makes contact with the car! I used masking tape to hold it in place while the adhesive was drying!
I drove my car 30mins after putting it on and nothing fell off, but leave it for a few hours.
To get tiger seal off or anything PU adhesive use petrol on a rag and just rub it off
My Bravo
klemster is offline Reply With Quote Quote
Thread Tools
