General nea and car is a p reg 1.6sx bravo
B
bravowes
Guest
hello i am new and i wanna ask sumthin i got a 1.6 sx bravo but when i put me foot down it takes ages to get to 3000rpm it seems slow for a 1,6 an ideales
Need more info.
Has it just started to do this or has it been like this for a while?
Has it had any work done to it recently?
Is there an injector or engine management warning light on dash? Injectors are a very common fault on the 1.6, i should know i've just fixed mine. Other faults could be sensors, spark plugs and HT leads.
no warning lights and only had it for 2 week not sensor lights nothin and will check the filter but its runs fine just very slow to get to 3000rpm
When my injector went, no warning light came up straight away. You could always take it to a Fiat garage and get an engine diagnostic done, these cost about £40 and almost always shows what the fault is.
how easy are they to do or just better goin to a garage to get it done
very easy, you can quickly diagnose the injectors with a multimeter, and then replace any using the numerous guides in previous threads.
personally i dont think its an injector fault.
