Ok so driving today and accelerate up then speedo drops to zero, then when i slow down it picks up again and then works fine for miles at 70, then on the way back was working then not working, always seemed to pick up again when i slowed for roundabouts etc then when i hit 4Krpm on the way out seemed to die and show zero again.
I'm assuming the Bravo HGT 155, uses a speed sender unit rather than a cable, i cant find my Haynes manual at the moment and am just in the door from the meet, so anyone got any suggestions on what to check etc.
Initially i'd thought it would have been a loose connection, but with it picking up when i slow down etc i dont know. Today is the first time this has ever happened.
Ok so quoting some info from previous posts:
And this thread:
https://www.fiatforum.com/bravo-technical/86206-speedo-problems.html?p=940437
Specifically this bit:
Seem to conflict
At the moment all the rest of the clocks work fine.
if its intermittent it definately wont be the sender unit at fault, it could be a wiring problem going to the instrument panel, but it will more likely be a dry joint in the instrument panel itself. its a common problem, i wish i knew exactly which joint always causes the problem because a quick touch with a soldering iron would fix it. since its intermittent it means the solder on the joint is probably cracked, but thats very very very hard to spot by eye unless you can follow the circuit for the speedo all along the pcb checking each joint as you go, there are wiring diagrams in the fiat manuals but not detailed pcb maps. if you like microelectronics get stuck in and see what you can find.
And this thread:
well done reading the other threads before posting
what a refreshing change!!
as you said, if its only the speedo that isnt working id attack this problem from the gearbox end first.
theres a good guide on fiatboo describing the repair procedure for the instrument panel if replacing the sender unit fails to cure the problem.
Seem to conflict
