Music Streaming
Music Streaming
sadler97
Hoylake
Hi guys i have recently purchased a 2012 fiat punto evo GP, i currently own a htc one m7 and there are a few features on the blue and me system which don't seem to be working with my current phone.
such as the message reader and the music streaming as I don't have a aux input does anyone know a way or a product that would let me stream music to my car ?
Adam
I had the same question when I got my Fiat 500. Blue&Me does not support A2DP bluetooth standard, so you can only use the bluetooth connection pick up and make phone calls.
I use Griffin BlueTrip to stream music wirelessly. It connects to your phone and as a cable connecting the unit sitting in your lighter output to the aux. It's very discreate. It helps that in the case of 500 12V output is next to the AUX. There are other similar solutions, such as TuneLink and eSync.
so if i purchase this product it will connect to my car via bluetooth and i use a aux from the blue trip to my phone
Adam
Go to play store and download the AudioRouter app (free). It plays music directly via the bluetooth to the cars speakers.
Does anyone know of an app that allows me to play music via the USB to blue and me??
Hi I own a 59 plate punto evo multiair 135 with stock blue and me blaupunkt stereo system with the Windows usb port but no aux input.
I have been trying to find the best solution to playing music from my phone / mp3 / music playing device and because they Changed the usb software in most devices (as you are all aware I'm sure) so that it is no longer recognised as an external hard disc, I may as aswell have been banging my head against a brick wall.
The best thing I have found so far is a TDK usb flash drive I bought today that has the capability of connecting to any android device that has 4.1+ jellybean software and be used as an external drive,
So you can plug it into your phone when on the go and quickly transfer a song etc to the usb stick (for Times when you've just found some banging tune you have to play just right now!)
Here is the usb stick it cost me £10 at Tesco.
In case there is any confusion the usb end of the stick rotates 180 degrees and slides into a little usb input on the opposite end of the android connection housing ( as seen in the picture.
Any other suggestions are much welcome.
