- Sep 27, 2008
- 7,105
- 819
ebay item number: 290262819808
and is it possible to get hid sidelights?
thanks
thanks
they're BULBS not a full KIT
A general rule of life is if looks too good to be true, it usually is; though ebay can sometimes yield absolute bargains!
2 why exactly would you need HID sidelights? Someone will probably make them but your main beams will over-bear them anyway
HID sidelights. You planning on trying to blind people when it's not that dark?
LOL at HID Sidelights.
Perhaps you mean "LED" rather than "HID"?
Have you ever seen one of those new fangled 'LED torches' using the super super bright LEDs'?
got 6 my dad is an led freak
They seem to give of the same sort of intensity as the average HID bulb, but on a smaller scale.
wouldnt know as said know little about hids other than 6000k are bright white which i would perfer to the standard yellow
Apparnetly LED headlamps will be the next advance in headlamp tech.
can you get led head lamps for the gp?
LED sidelights won't work in the Grande Punto as a straight swapout. Reason being is that they run on a much lower voltage than normal sidelight bulbs, and the computer system thinks the bulb has blown. The LED's actually flicker and look ****.
already read about that.
This is not a problem in older less computerised cars, e.g Mk1 punto etc.
no i do mean hid as cba with inline resistors even though easy to do
HID headlamps need 10,000 volt balasts installing to drive both headlamps to produce that intensity of light straight away.
didnt know that as said i know little about hids. so thankyou for educating me.
You ever seen a street light switch on? Notice it takes a good 1-2 minutes to go from dim to fully lit. Thats what HID bulbs would do if they werent supplied that amount of voltage in one go, hence balasts are needed.
once again. didnt know that as said i know little about hids. so once again thankyou for educating me.
You should by "xenon" filled sidelights if you want to loose the yellow look. (that said you'll likely have a blue tint with these type)
HID means "High Intensity Discharge". They're able to produce much more power than normal headlights. HID's in sidelights would be illegal as sidelight bulbs are only legal up to a certain wattage/ brightness.
LED sidelights however are legal as long as they are the same level of brightness as standard bulbs.
Unfortunately this is true my friend. Today i bought 2 white leds to fit as sidelights to my grande but they blink. If you put just the one and leave the other with the standard bulb it wont blink, but when you put both of them they start blinking...
