FIAT Auto Specialist Team
Thread Tools
Old 05-07-2019   #1
USA
Question Faulty locking mechanism - Passenger door
Hello everyone. My passenger doorís central locking mechanism stopped working a few days ago. I can lock/unlock the door from the inside (pushing/pulling the passenger handle in/out), but locking via the remote or the driver sideís physical lock doesnít do anything.
The rest of the door mechanisms (driver and trunk) are working fine, so my guess is that the issue is with the passenger doorís locking mechanism. Before I go and take the door apart for fun, can anyone share whether my diagnosis is correct, and whether the mechanism is actually in the door or not? (Could it be a wire leading to the door, for example?)
Also, if anyone has links to replacement parts for this, that would be super great!
benstick is offline Reply With Quote Quote
Old 05-07-2019   #2
typecastboy has donated!
You can get the parts on eBay.
I believe the rod has come off at the top, quite a common thing. Take the door card off, cut and peel back the lining and get a torch in there. If itís come off chances are it will keep coming off so you either need to replace the little nylon clip that holds it in or as I do with these put a small thin cable tie round it to keep it in place.
You can see my video which shows the drivers side
Thanks jrkitching thanked for this post
typecastboy is offline Reply With Quote Quote
Old 08-07-2019   #3
USA
Re: Faulty locking mechanism - Passenger door
Really?? Thatís all there is to it? You think itís just the plastic clip and not a relay/motor?
Iíll try and open up the door next weekend. See what I find. Thanks for the quick response and the tips!
Old 08-07-2019   #4
Quote Originally Posted by benstick View Post
I would bet my pension on it.
Old 18-07-2019   #5
USA
Alright. I'll definitely give it a go, then.
They still have pensions in the UK? :P
Likes typecastboy liked this post
Old 18-07-2019   #6
Small ones.
Likes isthisagoodidea, jrkitching liked this post
Old 21-07-2019   #7
USA
So I opened the door today, and unfortunately, it's not the wire. It was still attached to the indoor door handle with the little plastic hook.
Since I don't hear any motor/relay switching on when I lock/unlock the door with the remote, i'm leaning towards the actual locking mechanism being faulty.
I'm just not sure if the problem is there (the mechanism on the door) or elsewhere (wire leading from the central logic unit to the lock).
I'm leaning towards the mechanism itself, since the rest of the locks are working fine.
I can't post URLs, but do you think this part # will do it?... 51827415
Thinking of getting a pre-owned mechanism, which is about 20 GBP.
Thread Tools
(G) Rear passenger door not locking with central locking emswwfc Grande Punto 17 20-06-2018 11:18
(T) Faulty central locking back door only Stealth123 Stilo 7 30-11-2013 02:01
(G) faulty door mechanism Ian1987 Grande Punto 5 25-11-2011 10:50
(G) sliding door locking mechanism caledonian1 Doblo 2 06-12-2009 10:46
(G) Rear door locking mechanism pritch Punto (Mk2/2b) 3 27-05-2004 07:11
