I'm just compiling a list of the oils and fluids needed to refill our 900t when the engine and gearbox etc. goes back in (and for general servicing in the future).
The Haynes manual states the following:
Engine Oil: Castrol GTX
Transmission: Castrol Hypoy B Gear Oil
Wheel bearings: Castrol LM Grease
Brake fluid: Castrol Girling SAE J1703c
Obviously technology has moved on and modern fluids are better (maybe). However, I'm very aware that you can't just 'fill her up' with the first thing that you pick up of the shelf. In the case of brake fluid this could lead to disastrous consequences.
Searching online is more confusing than helpful.
What does everyone else use?
Thanks in advance.
Thanks in advance.
