FIAT Auto Specialist Team
Thread Tools
Old 18-11-2015   #1
AndyBense has donated!
Electronic Ignition
Has anyone replaced the distributor, or fitted a conversion kit, to upgrade to an electronic ignition? There seem to be a few products available for the fiat 126/500/600 to either replace the whole distributor or to convert the existing distributor. I've found a few kits for the 850 but not yet sure they'll fit my '74 850T.
AndyBense is offline Reply With Quote Quote
Old 19-11-2015   #2
Re: Electronic Ignition
Hi
I've been considering the same on our 900T (Connie) as part of the rebuild - I remember back in the 80's that you could get after market devices to do the job (Sparkright being one of the main ones).
I haven't got to it yet (engine still on the garage floor) but here are links to some possible contenders that I've found:
http://www.boyerbransden.com/IDunits.html
http://www.newtronic.co.uk
Hope this helps
Gary50 is offline Reply With Quote Quote
Old 19-11-2015   #3
Quote Originally Posted by AndyBense View Post
I fitted a Lumenition Magnetronic Ignition Kit to the original Marelli distributor on my 850t (it does have an 850 coupe engine fitted though) a couple of years ago. Fit and forget, dead easy to install, never had any problems with it, wholly recommend (I got mine from Demon Tweeks).
doglog is offline Reply With Quote Quote
Old 19-11-2015   #4
Thanks for the info.
I'd been looking at the ultra spark units from ignitioncarparts (ICP-EK004) - wouldn't let me post the url. Not yet sure whether they'll fit the 850T but they look similar to the Lumenition kit.
Old 23-06-2017   #5
Anyone manage to find anything for the 900T ?
1979 Fiat DeVille
1979 Fiat 900T
1976 Fiat 126
DeVilleChris is offline Reply With Quote Quote
Old 10-07-2017   #6
Maigretnz has donated!
New Zealand
http://www.ricambio.co.uk/69-fiat/53...-spinterogeno-
or a cheaper option would be a PERTRONIX IGNITOR III ELECTRONIC IGNITION KIT
Maigretnz is offline Reply With Quote Quote
Old 04-02-2019   #7
Quote Originally Posted by doglog View Post
Hi
I've been looking around and the Lumenition electronic ignition conversion looks a good choice - there a 2 or 3 options.
However, none of the online shops (I've found) list a conversion kit for the distributor fitted to my 900t - Marelli S118CA. Looking at the list of distributors listed in the Haynes manual none of these have a conversion kit listed either.
The enquiry responses from the re-sellers haven't been encouraging/helpful - I'm still waiting to hear back from the manufacturer.
Can those who have the Lumenition kit share what distributors they have and which kit/part number they have?
I suspect that (if there was a specific kit) in the past that this is no longer produced. However, there may still be one gathering dust on a shelf somewhere - knowing the kit number will help track it down.
Thanks in advance.
Old 17-02-2019   #8
Still no joy tracking down a suitable electronic ignition conversion kit.
I'm thinking that I will need to put up with the standard ignition for now. Consequentially, I've had a better look at the current distributor to see what parts may need replacing. The points look okay (but will replaced as over 12 years old) however, the distributor cap has some issues.
Firstly, when sat on the distributor there is around 2 to 3mm play where the 'notch' fits over the LT connector - this will obviously affect the point where the rotor hits the contacts in the cap (effecting timing). Looking at where the cap fits on the top of the distributor there is nothing obvious to indicate where to line the cap up.
Probably as a consequence of the above one of the contacts in the cap has a grove cut into it by the rotor - the other 3 contacts look in good shape. I've got a couple of old distributor caps and they all have the same wear pattern.
I'm hoping there is a simple fix but if I have to replace the distributor are there any alternatives to the Marelli ones? Or even a way to go straight to electronic ignition?
Old 17-02-2019   #9
Patinated Peter
fiat500's Avatar
fiat500 has donated!
It would cost you a fortune but I'm pretty sure that the company that makes the 123 ignition would do you a one-off conversion as their listings for various options available state that the existing unit is needed.
Alternatively you could have the original distributor overhauled. On my 500, with the distributor in good nick, there is no discernible difference in performance from using the electronic ignition.
fiat500 is offline Reply With Quote Quote
Old 17-02-2019   #10
Hi Peter
By luck I found 123 Ignition this afternoon (before I saw your post) and have sent them an email to find out pricing etc.
As a price point I've spotted a Magneti Marelli S156 distributor which is supposed to fit the 900T (I'm waiting on confirmation), this is around 350. Add on the cost of the electronic conversion (around 200) should give a fair comparison between both options.
In the meantime I'll check out how much it will cost to have my alternator overhauled - not sure if this is a DIY job or something to trust to the experts?
Likes fiat500 liked this post
Old 17-02-2019   #11
Patinated Peter
fiat500's Avatar
Quote Originally Posted by Gary50 View Post
If you can get the parts, overhauling an alternator is fairly easy. The bearings should be readily available and then you will need the brushes, maybe (but probably not) the diode-pack, and the regulator (if it's a separate item). I did it with the 500 and parts were less than 40 total and the potential for seriously worn out parts seemed less probable than on a dynamo.
Old 18-02-2019   #12
I've had a reply from 123 (www.123ignition-conversions.com).
The price to convert my existing distributor to their 123Tune+ is €565 (approx. 500) including a new uprated coil. Approx 10 days turnaround.
It is a little pricy but when you look at what you are getting it's not too bad.
Firstly it just fits in the same hole that the original distributer fitted in and there are no extra boxes or wizardry to fit.
The real selling point (to me) is that you set the timing using your iPhone/iPad using bluetooth - much easier. It also has a built engine immobiliser (PIN code), something else I was going to buy but won't need to.
The App also has a dashboard that shows engine revs, temperature, battery charge etc.
I'll let you know how I get on.
Old 18-02-2019   #13
Patinated Peter
fiat500's Avatar
The price to convert my existing distributor to their 123Tune+ is 565 (approx. 500) including a new uprated coil. Approx 10 days turnaround.
The version I bought for my 500 lacks all those additional functions and was 224; that was a couple of years ago. It would cost a bit for a new standard one or to have your existing renovated; so that is not actually an unreasonable price.
Old 23-06-2019   #14
Further to my comment about letting you know how I've got on...
It's been several weeks since I've had time to work on Connie (other DIY jobs), and a little longer since I have started her up. So I thought I'd fire her up today and see what happens.
Even when Connie was regularly on the road (over 10 years ago) it was always a case of fingers crossed and hope for the best when turning the ignition switch. One or two days on the drive usually meant a good ten minutes or more cranking and a 50/50 chance of the battery running flat before she fired up.
Ignition on (fuel pump running), half choke, turn ignition.... fired up immediately and I've still to fully adjust the timing and carb settings
Unless you knew what to look for you wouldn't guess that the dizzy was electronic.
Not only that but it comes with bluetooth connectivity and a load of information displayed via the 123 App - shown here on an iPad.
I've still a lot of work to do before I can take her out on the road but at least I know that she will start now (so I have a chance of getting on the road).
Old 25-06-2019   #15
phate316 has donated!
What electronic fuel pump did you fit in the end
phate316 is offline Reply With Quote Quote
Thread Tools
(T) electronic ignition capristeve X1/9 16 19-01-2012 11:45
(T) Electronic Ignition? Blurredman Panda (Classic) 3 30-08-2010 00:42
(T) Electronic Ignition Alan.D Panda (Classic) 24 16-02-2010 23:13
(T) Electronic ignition shaun X1/9 3 25-08-2008 20:01
(T) Anyone fitted an electronic ignition to the Xy bigfatbloke71 X1/9 4 09-12-2007 15:06
