Hello!
I have run into an electrical problem with my 2013 Fiat 500 Pop. Originally, the socket for my right passenger side daytime running light was not securely holding the bulb. I had my local mechanic replace the socket. Now, that light is far dimmer than the other driver's side running light, and I get the "Check Daytime Running Lights" message. So even though one side is fine and one side is dim, the car thinks something is wrong.
Additionally, when the headlights are turned on, I get the "Check Running Lights" message. The passenger side running light doesn't come on at all, and the passenger side tail light does not come on, but still works fine when hitting the brake.
I'm going to Pep Boys for an electrical diagnosis, but any advice or similar situation advice would be appreciated!
