Mechanical regulator putting out 20volts.
Delay in my electronic voltage regulator, want to get this back in for a few days.
the cut out on the far right got bent while removing the cover. finding it difficult to bend back, should I just be patient and wait a week for the electronic or is it worth messing with.
Also, is running the motor the only way to adjust/fine tune it? Is it literally just bend, check readings, bend, check readings, bend, check readings........worried i will blow something while I fiddle with the adjustments.
