C crozell New member Joined Jan 24, 2009 Messages 12 Points 7 Apr 23, 2009 #1 The driver's side headlight works on high beam but not low beam, the passenger side works fine on both? How do i go about fixing this? thanks for all of your help. clay
P Panda Van Is all gone square shaped Parked in the garage Joined Apr 4, 2007 Messages 675 Points 168 Apr 23, 2009 #2 Check all the earth ground points and that all the fuses are making good contact in the fuse box - failing that shout at it and waggle all the wires!
