im Axle Specialists
Old 25-01-2010   #1
USA
Hard starting when cold
I have a '78 124 that does not like to start up when it's cold outside, (to me that's 45 to 50). It starts up and then putters out. It takes a light touch on the gas to keep it going without backfiring and quitting. I have rebuilt carb, replaced timing belt, valve shims, tune up, adjusted timing... It runs good after it warms up, it's just when cold. Any ideas on what to check?
rasouth is offline Reply With Quote Quote
Old 27-01-2010   #2
USA
Re: Hard starting when cold
lots of things to check:
1. the gap of the points, both sets
2. idle solenoid, is it working?
3. choke setting. is it working...
4. idle mixture and idle speed settings
the choke is where i am leaning first. with the top off the air breather, and it is 45F, with the engine cold and not running.. are the butterflies closed? as the engine warms up, do the butterflies slowly open?
double check to see that the two hoses supplying radiator fluid to the water choke are both connected and intact. if not, here's the source of the malfunctioning choke.
Mike Bouse
[EMAIL="mbouse@chartermi.net"]mbouse@chartermi.net[/EMAIL]
Coldwater, Michigan USA
Home of the [B][COLOR=red]Michigan SHORTER SHIFTER[/COLOR][/B]
member, Fiat Lancia Unlimited
mbouse is offline Reply With Quote Quote
(T) Hard too start when cold bzxhms 500 6 12-12-2009 14:34
(T) Hard Starting darron Uno 5 05-02-2009 07:53
(G) brava td 75 hard to start when cold bravad Bravo / Brava 4 29-01-2009 19:50
(T) 1.9Mjet Hard to Start from Cold alexh365 Grande Punto 10 03-09-2008 19:15
(G) Going hard into first when cold healed with oil change oktopod Punto (Mk2/2b) 4 08-04-2008 00:20
