Thread Tools
Old 04-05-2019   #1
USA
USA spec.........rear fog lights
In the US spec 124 cars, the rear fog light lens exists, but has no bulb sockets.
I would like to activate them. In order to do this, I have ALREADY INSTALLED two sockets and bulbs in the empty areas.
Now, The wiring for the rear fog lamps already exists, it is "parked" in a dummy socket.
The problem is that I cannot seem to get power to that existing wiring. When I activate the front fog lamps via the factory switch, NO POWER appears at the existing REAR fog wiring.
Both fuses 27 and 29 are OK, they are labeled "FOG LIGHTS" and "STOP / REAR FOG LIGHTS" respectively.
So, my question is.... Is there some OTHER fuse not shown in the US spec manual which needs to be installed in order to continue power on to the existing rear fog wiring?
OR, lacking that info, has anyone found a PATH THROUGH the convertible top well in which to run a new switched wire? I've poked around for hours, and can't seem to find a clear path from the trunk into the vehicle interior.....
Thanks !
"Take the Cannolis!"
stevebad is offline Reply With Quote Quote
Old 04-05-2019   #2
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: USA spec.........rear fog lights
If the 124 is anything like other modern FIATs, the fog lights are not controlled by a simple switch and relay system, but rather by the body computer - the switch sends a signal to the body computer, and it in turn switches the relevant relay(s). In other vehicles (from experience with the Grande Punto) if the vehicle was not supplied with fog lights, then the body computer will not be configured to accept input from that switch.
It may be possible to reprogram the body computer, but that's beyond my ken.
The simpler option would be to use an aftermarket switch.
Eklipze3k is offline Reply With Quote Quote
Old 04-05-2019   #3
USA
Thanks for the reply....... Now the problem will be to find a path for the switch wire thru the convertible top storage well.
Old 6 Days Ago   #4
''LUIGI''
2668GRIFFIN's Avatar
2668GRIFFIN has donated!
Hi
Most fiat dealers will be able to enable the body computer to accept your fog lights
They can do any updates [like any laptop or home computer] while they are there
LUIGI
2668GRIFFIN is offline Reply With Quote Quote
Thread Tools
(T) rear fog lights ninesheds Ducato 9 04-12-2015 18:48
(T) High beam lights, fog lights, rear demister and fan for heater/air-condiioner AndrewGeorge Punto (Mk2/2b) 2 26-05-2014 06:10
(T) Rear fog lights thehumph Punto (Mk2/2b) 6 20-01-2010 08:16
(G) how many rear fog lights? colezy Doblo 4 12-11-2009 12:43
(G) black rear lights, uk spec. normski c Cinquecento / Seicento 2 10-07-2005 18:18
