rogerhallorkney
Hi guys,
I have a 2004 ducato based motorhmome. 2.8JTD engine
I little while ago the speedo stopped reading correctly, it was reading only 20% of actual speed. i changed the sensor out but that didn't sort it. the mileage is still going up correctly though.
then very recently the battery was flat - i jump started the van and now the speedo sits at 110mph when static. i haven't driven anywhere yet.
the van idles perfectly well but when i press the accelerator it dies momentarily and then picks up and dies then picks up etc. if i accelerate slowly it revs up to 3000rpm with no dying off. quick presses see it die off and pick up. i get a flash of engine light which then goes out again.
i should make a little video and post here too to better explain the issue.
I have been advised to check the earth straps and check the fuel lines for leaks. i have changed the fuel filter which made no difference.
any ideas would be gratefully received.
