nothing bad happened to the valves during the belt change, i know that 100%.
how can i be so sure? you did 26000 kms without a problem, so obviously the valves were fine after the belt change.
that doesnt mean they are fine now.
you recently did a compresison test, that tells you the valves are fine and the timing is correct, same as when the timing belt job was completed.
