Timing sensor (cam sensor), crankshaft position sensor (rpm/tdc sensor) and knock sensor could be the problem?
crankshaft position sensor would cause more serious problems like cutting out and a very erratic idle. this fault does not always show up on a diagnostic, but the symptoms are so noticable that you couldnt miss it.
a faulty knock sensor would cause ignition timing to be retarded (by approx 5degrees) so you would get a loss of performance. this could be your problem, however a fault that results in retarded ignition must also result in an error code been stored in the ecu. if you dont have a code (such as P1225) then your ignition is not retarded so you can rule this out.
a faulty cam sensor can cause a variety of fueling and ignition problems, and like the crank sensor it doesnt always trigger a fault code. my gut instinct tells me your problem is not the cam sensor, but in your situation i would replace it just to be sure.
Can you tell me what the abbreviations IACV and ISCV stand for?
idle air control valve and idle speed control valve, both mean the same thing. basically there is an actuator that moves to alter the amount of air that passes through the throttle body, this alters the idle rpm. if your car has an idle rpm that does not adjust to maintain the 850rpm when warm, and does not increase to a higher rpm on a cod start, then your iscv could be faulty, well the actuator is the part that will be faulty. your problem doesnt mention an idle issue so this cant be your fault.
I heard from someone in here in Ankara that 97 and 98 hgts suffered from variator.In order to prevent these mistakes authorised dealers called the owners and changed the engines.But in that time I got no calls from the factory and the dealer.Did you hear something like this?
How can I check the variator? Can I do that by myself or a authorised dealer is needed?
i have never heard about a recall, but the variator is a common fault on almost every fiat group engine that uses one so it would be wise to change it at the same time as the second timing belt change (approx 70k).
you can tell if the variator is faulty, when you start the engine it will sound a bit like a diesel. you can also reomve the timing belt cover and watch it to see if it moves when you rev the car, it should move the pulley at higher rpm.
