anybody here have a towbar on their GP? want one that wont need the bumper cutting out
dont think that can be done due to the shape of the bumper (then again someone had a flange ball fitted without a cut)
but the cut can't be seen this is my brink on the active (is the bumper any different anyway?)
https://www.fiatforum.com/grande-punto/142997-you-know-you-want-towbar-gps.html?p=1518820
also be aware it obstructs the rear towing eye point not a problem read my last post in the above
It can be done, you need a swan neck tow bar. (looks a bit weird)
I had a Brink detatchable fitted 3 weeks ago. You can barely tell it has been fitted once it is removed - you'd have to be on you hands and knees behind the car to know it had a towbar fitted and following the car on the road you'd never know.
The bumper has to be cut due to the shape of it, but all the cutting is underneath. The fitter who did mine kept the cutting to an absolute minimum, which makes fitting and removing the blanking plate a bit tricky, but he said had he made it easier, then the cut would be visible. It works fine and it looks OK, which is all you need. I'll try and post some pics a bit later on...
I'll try the towing eye tomorrow then...:chin:
Not had chance to do the pics yet - tomorrow hopefully.
what it is with the towing eye is, the flange plate that bolts to the chassis rail covers said towing eye hole.....
I got a large shackle with an internal diameter/space of 40mm(ish) so if the worst comes to the worst i can have it pulled out or give someone a tow....
You dont need your rear towing eye if u have a tow bar fitted. Hence the name!!
