M Matt2 New member Joined Jun 22, 2014 Messages 4 Points 3 Jun 26, 2014 #1 I've got a leak that appears to be coming from the sunroof, any ideas how to fix? Thanks Matt
Wee Smurf Yellow is the way to go! Joined Aug 9, 2005 Messages 3,903 Points 763 Location Belfast Jun 26, 2014 #2 Have you checked around the seals? Give them a good clean to see if it improves things.
A AB100 Established member Joined Mar 16, 2011 Messages 1,947 Points 496 Jun 26, 2014 #3 Matt2 said: I've got a leak that appears to be coming from the sunroof, any ideas how to fix? Thanks Matt Click to expand... Need to check water is draining away as well - drain holes may be clogged. Pouring water into the channels will tell you - if it doesn't drain away
OP OP M Matt2 New member Joined Jun 22, 2014 Messages 4 Points 3 Jun 26, 2014 #4 Thanks for the replies. eLearn says there are no drainage holes on this model?
A AB100 Established member Joined Mar 16, 2011 Messages 1,947 Points 496 Jun 26, 2014 #5 Matt2 said: Thanks for the replies. eLearn says there are no drainage holes on this model? Click to expand... Hmmm. Sounds unlikely but the cars not here at the moment to check. The Aygo I hired in Spain had a leaked caused by the aerial being loose - is it that? Where's the ingress?
A AB100 Established member Joined Mar 16, 2011 Messages 1,947 Points 496 Jun 26, 2014 #6 Looked at out pan roof. Looks like the water drains down inside the A posts. There is a gap in each front corner. Stick the car face down on a slope and pour a kettle of water in the channel. See what occurs.
