dumbledore
- Joined
- Jul 4, 2010
- Messages
- 745
- Points
- 144
This is good. Unless your temperature sensor is lying your thermostat is buggered. It does not allow the coolant to flow and overheats the engine.
My best guess, fubared water pump. You can check the condition of the impeller by draining the coolant (keep it if it has good antifreeze in it) and removing the water rail.
If thermostat was shot, I'd expect bottom pipe to be warmer -- eventually -- than the top one.
Still, stats are cheap. just beware of no-name ones.
i am not happy with that thing ... still.. ok temp is down by 1/4 of scale, but now, when i driving in city, temp fluctuate between half to 3/4(seems to be thermostat does the work, and coolant goes through rad, ... when i was checking it, both pipes was veeerrryyy hot, fan kicks in), even with heating on full hot and ventilator on position 3. havent chance see it on motorway.
when i was changing thermostat yesterday , i checked internal surface of engine through thermostat hole, and it was kind greasy, brown ish fat on internal engine walls. what could be that ? would it cause my engine overheating ?
BOTH HOSES are hot makes it likely the water pump isn't pumping properly. If so change the cam belt as well.
When done fill with water only and chemical cleaning solution like radflush. When clean refill with water.
This might uncover leaks but better to find them before they cause yet more problems.
If needed new rads are about £35 & easy to fit.
When it's clean and not leaking dump the water, pour in 2 litres of antifreeze and top up with water. That way it's at least 50%.
what you think, would i need change piston rings ? as i have to change crankshaft seal, have to take off oil sump. (there was no smoke before).
Your guess is as good as mine. By pulling the head before doing a compression test you destroyed the easiest way to come to a decision.
For sure, one chamber is a little more carbony than the others. This might be rings, valves, valve oil seals. Go measure.
Read thread from beginning, i have tested pressure. there are some pictures with tests and measurements .
Collected head from machine shop now. compression test ok, valve pressure test ok, skimmed and cleaned.
So , what about rings ?
