Technical Stilo ecu pins
Hello and greetings from Finland,
I have Stilo -04 1.6 and I need diagram for ecu pins. I donated and downloaded eLearn cd but it doesn't work with my mac.. So can someone post a picture? Thanks!
Thanks but that doesn't help much, I am a bit newbie and don't understand the destination codes. I should've asked straight away which pins connect to the accelerator pedal? :D Maybe I'll make a new thread considering my trouble. I have some intermittent fault with acc pedal(P1221 error, goes to limp mode) and rarely the pedal doesn't react at all (engine stays idle). After I release the pedal up it responds normally again. Done a lot of things, cleaned connectors (incl. D4), changed acc. pedal, throttle body from other stilo... So it could be Ecu or oxidation inside Ecu connector (if it's even possible). Next thing that I'll do is open Ecu connector and check that everything is ok there. But which connector connects to acc pedal?
And sorry for my bad english..
On the wiring diagram, M10 is the engine management ECU. K55 is the accelerator pedal sensors.
Wiring colour codes on eLEARN wiring diagrams are not always accurate, but these are what the accelerator pedal is shown as.
AR Blue/Red
MB Brown/White
RV Red/Green
VB Green/White
AG Blue/Yellow
HV Grey/Green
Hello from Czech Rep,
I have Multipla -06 1.9MJet and I need diagram for ecu pins(0281012294 - 55200651). So can someone post a picture? Thanks!
Just wanted to inform that car has worked fine for many days now! I just done the old "jiggle-the-connectors" fix for ecu. :D We'll see how long it will last without engine fault.. So definitely something wrong with the connector.
OK
I'll say it differently
please I need diagram for 88kw ecu pins(0281012294 - 55200651). So can someone post a picture? Thanks!
