The gearchange on my tipo is a bit loose. Took the gator off and i can see the nylon pivot ball, thing is I can lift the gear stick upwards about 6-7mm as the ball isn't tight in it's cage.
Should it be? If not how big a lump needs replacing underneath? Same on any other cars? 5 door Sedici? Worth while replacing the control arms with rose joints on threaded bar at the same time?
There's a couple of other things I need to tighten up on the car, going to change the lower arms and track rods - and check the state of the steering rack as there is a little bit of play in the steering.
