hi Guys, excellent guides to the sunroof. My sisters Stilo roof has jammed. I removed the sunroof and stripped it down, as the left side was not driving, only the right, from the fully closed postion.
I found the cable was fine, but the sliding bracket assembly on the left hand cable had the front edge broken off.
I rang Webasco and they can not supply any parts. Rang some dealers and again, no parts. My local Fiat dealer was very helpfull, but again only a limited number of parts available, and nothing for the cables.
The mechanism is very complex and clever. The control cable operates a slide assembly at the front of the sunroof. this slide assembly is attached by a small white plastic round section rod (very hard to see), to the rear sliding block assembly. To remove the front slide assembly you need to remove the front stop assembly and a lot of the front tilt mechanism. Then at the back, there is a stop bracket (L shapped) and then you must remove the 4 small countersunk screws and the 1 pan head screw, in the upper side of the track, which releases a white plastic runner in the track, which is pretty much hidden.
The front slide assemblies, work a sort of ratchet mechanism on the sliding track. The initial reawards movement when Open is selected, slides the front glass mechanism back, which tilts the pane up, but does not move the rest of the glass mechanism, which held shut by a small plastic spring loaded button in the track, just behind the front glass. When it is fully up, a rachet is released and the front pane mechanism is released and now the next sections of glass are pushed rearwards, after the plastic spring loaded button is released.
When you close the roof, the rear sections are all pulled forward until they are stowed, the plastic button drops in its hole, and then the ratchet is released, disconecting the fwd slide from the main mechanism, and it pulls the front glass mechism fwd, to drop it down. Very clever, but complex.
Anyway the L/H cable sliding assembly on ours, has its front section broken off and we need a new L/H cable/slide assembly. Has anyone got spares left over from previous repairs and would be willing to sell a spare.
Just for info;
The sunroof is not hard to remove.
The front and rear motors are independant, (front for roof, rear for the blind)
The reset procedure for any problems, is rotate the rotary knob anticlockwise, then press the rotary knob in and hold in while it sorts itself out.
Many thanx Tim
