Technical Side lights
Kiltedboarder
Hi all,
Anyone got any tips to keep the front side light bulbs (the little ones) that sit below the main bulbs night and tight in their holders. They are very loose and keeping going out. If I wiggle them then they come on but putting them back into the headlight holder puts them off again
I’ve looked in the holder but can’t really find a good solution
I had the same problem, ended up removing the bayonet fittings and bending the locking tabs inwards a bit to clamp the bulb a little tighter and bent the contact tab in the base up a bit to increase the sprung tension in the fitting.
Thanks guys, I played with the contacts a bit and seem to have a solid enough fit now. Let’s see after a few miles driving
