E energyman New member Joined Dec 29, 2011 Messages 30 Points 7 Jan 11, 2012 #1 Anyone know where the relay that operates the Selespeed pump is located in a Grange Punto??
D4nny8oy Established member Joined Apr 6, 2007 Messages 2,883 Points 433 Location Yep, still here. Jan 11, 2012 #2 energyman said: Anyone know where the relay that operates the Selespeed pump is located in a Grange Punto?? Click to expand... I'm confused? You said you had 12v at the pump, which must mean the relay is working https://www.fiatforum.com/grande-punto/290042-failed-selespeed-pump.html
OP OP E energyman New member Joined Dec 29, 2011 Messages 30 Points 7 Jan 11, 2012 #3 I just want to check that I have not got any high resistance across the relay contacts and that it is functioning 100%. Thanks
