I'm getting an intermittent screeching noise when trying to start my 56 plate GP 1.2 Active
Basically, the car starts fine 99% of the time. The other 1% I get a loud screeching sound when I turn the ignition key and have no choice but to switch off. It won't start + it sounds really bad, like when you grind the gears!!. I will leave it a couple of seconds & try again - sometimes it will do the same for two or three attempts & then start normally??
I've got no idea what it is, just that it sounds really bad & can't be doing the car any good....it seems worse in damp weather & on cold starts. I can only remember it happening once when the engine had been warm, stopped at Tesco for 15 minutes when I came back out - same thing??
As soon as the engine is running, it doesn't make the noise - it's only when starting up??
