1.2 8V. Had head off, skimmed, valves reseated and seals replaced by specialist. Car has had new MAP sensor and coils. I set the timing by lining up the mark on the flywheel with 0 on the gearbox casing and set the cam using mark (cams on No 1 cylinder were both pointing up slightly from horizontal.
The car is idling rough and is very hesitant under acceleration. Lack of top end power. Shaky on idle. I have 2&3 plugs firing on front coil and 1&4 on back one.
Does anyone have any idea what I need to check/do please? The plugs are sooty and so is the newish lambda sensor (top one) which suggests it's running rich. Is it a case of adjusting the timing and if so by how much? Ta
