Technical removing front ,,dashboard,, ?
doodledo
i have dual klimate control and now where is the point where i want to say ,i should have taken simple climate control:D.
So to the point , some motors dont work ,some makes bzbz noises and ect, i am curently removing front ,,dashboard,,-(dont know correct word picture named antras.jpg shows what i want to do , so i disconnected plenty of things and ,where is some thing which seems to be part of air bag system( i have picture of it circled red atached ) how do i disconnect it properly ?
so for airbags i removed battery , and i will disconnect airbags .
my primary qoestions is , will it be wrong if i drive a car with removed airbags passenger and steering wheel one ?
The connector circled red in your picture is not for the airbag, it is the radio aerial lead.
Most of the climate control actuator motors are accessible without removing the dashboard.
Is right actuator supposed to switch from engine heated air to cold ?
Thanks for replay ,its long story with motors. At first i cant control where air goes like legs, middle or windshield, when i started to get hot air to driver and cold to passenger ,when opposite, later only hot for both , after few recalibration procedures, only cold. Now its sorta mix between outside air and conditioned cold/engine heated, i see most of motors but they do nothing for few months and only one working makes constant bzzzzbzzzz bzzzz and it feels like it sits somethere in the midle of a car, also climate reset doesnt help, it ends with error 1 blinking . So i just take all front out , and when check everything , or let it do for some mechanik , still without all plastics on top it will be cheaper
