LuigiMorelli
- Joined
- May 1, 2018
- Messages
- 11
- Points
- 3
Hello,
I have just experienced the following issue on my FIAT500 from 67: when blinking to the right; both brake lights also turn on at the back and blink at the same time as the blinking light. When braking, the blinking light also comes on (continuously).
This happened fairly suddenly. We checked all the connections and all the cables seem to be in the right place.
We removed the ground connection from the rear right side blinking light and of course it stopped working. The brake lights still worked then. With the ground connection removed on the right handside and blinking left, the brake lights came on. The left side works otherwise normally when the grounding on the right side is connected.
Any idea where I should look?
Thank you! Grazie mille!
