Technical Passenger door plastic bonded window.
The small quarter window, above the door mirror on a used replacement door is cracked so i want to replace it with the window off my original car door. Does anybody know how i can get this off without breaking it ?
Might also be worth warming the plastic up with a hairdryer or heat gun (not too much though) as this may soften the adhesive and make it easier to cut through with a cheese wire type tool. Also easier to remove the surplus adhesive after you have cut it off, if it is warm.
