Technical Panda 169 trunk lid Plastic questions? And lock system
ıstanbul
Hello, I have a small question about my tailgate?
I see a button in the plastic. Normally, should the trunk lid be opened when this button is pressed?
I'm not sure if it's a button or something else.
My meter is not sending a signal. I couldn't observe a switch.
Question 2) If it is a button, how can it be repaired?
I only see the two wires for the number plate bulbs
I can't see in the photos the other two that go to the switch
I suspect your car never had remote locking or remote boot opening
Can you unlock the car by pressing a button on your flip remote key?
Or is it a manual only key,
Remote opening did not became standard on the 1.2 until around 05/06
There are 4 cables in the socket.
2 of them are minus parking lights.
1 plus.
There is 1 cable I don't understand.
There is a trunk release button on my remote control. I can open it with the remote control.
My car 2005 model.
yes yes thank you so much.
There is no clicking sound. The key is broken.
There are very few pandas in my country.
I had never seen the car up close before I bought it.
For this reason, I may have difficulty knowing how some things should actually be.
If I hadn't taken it off to paint, I wouldn't have known that such a button existed.
The waterproof button is a very smart solution.
Let me finish my work and share the topic you sent the link to.
Things got a little confusing. Some changes may have occurred due to third-party remote control system.
I need to do some work on this issue.o_O
The two brown cables have been connected before. But they are not connected anywhere now.
Moreover
2 of the 4 cables in the trunk lock are broken.
What do these cables do?
Despite this, the lock fulfills all its features. Very interesting.:unsure:
Also when I connect wires instead of buttons. So when I make a virtual button.
Trunk lock does not open automatically.
Could this be related to broken cables?
I repaired 2 broken cables. I think my front dome light now turns on and off depending on the trunk.
I completed the button assembly.
Even though I made the connections, I cannot check my luggage via the button.
Because my central locking system is aftermarket.
I think the remote control was lost or broken, they found this as a quick solution.
Now I have to check if there is a fault in the original lock system.
And I will investigate how I can return to the original control system.
Also, as seen in the video, the trunk lock does not work when pressed repeatedly.
It works normally but when you press it a few times it doesn't work for a while.
I think the lock motor's gears are stripped.
I couldn't find this lock in my country. It is not available in Fiat service.
I'll try to find it if I can't find it. I'm thinking of connecting the Universal Center lock motor to the wire.
  • VID_20231202_221549.mp4
    32 MB
