Technical Panda 169 Driver airbag lamps
ıstanbul
Hello. I haven't seen any problems with the wiring yet.
When I hit the front fuse panel with my hand, the fault light goes off.
When it goes off, it turns on the passenger lamp first. He then extinguishes them both.
I have yet to discover a fault in the wiring. But does he have a known chronic problem? Like sockets darkening?
Isn't the passenger airbag button marked yellow on the dashboard?
Isn't that the red driver's airbag?
The passenger key works pretty well. When I turn it, the yellow light comes on. When I call again it is disabled.
I took my first night drive with my car. The red light turns on and off slightly as you go over bumps. I think there is a lack of contact, I will check the sockets and cables again.
Yes
But there is a resistor for passenger airbag on and a different resistor for airbag off, if the system detects open or short circuit the red light will come on
When I punch the fuse panel a little, the fault lights go off. It may then light up again after a pothole or crash.
When I connected it to OBD before. It gave the passenger airbag fault code.
Maybe it's like you said.
What should I do in this situation? I can turn the key. Or I can remove its socket.
Since you said the resistors are different. There would be no point in canceling the switch by turning it completely to the short-circuit position.
