Panda Panda 100HP project (cooperman style!)
Right thought I would start a thread as there are a few mods happening to my panda and wanted somewhere to have them all in one place! I have owned my 100HP since 2010 and love it! She gets serviced at fiat evry year and had belts and water pump replaced last year. I wanted to start modding her but not go OTT as been there and done it before! Hopefully you guys like it!
So this is what I have done:
Day one cleaned!
BMC Panel filter replaced and clear indicator bulbs front and back fitted:
Before
After
Gear leaver blue detailing done with touch up pen:
Ultersport rear 80mm back box fitted, with multi hole exhuast rubber to space it away from the bumper:
Before
After
Home made induction mod give great induction noise over 3000rpm!:D here is the link to how I made it https://www.fiatforum.com/panda/319449-100hp-induction-mod-under-30-a.html:
Before
After
New tax disc holder fitted:
Before
After
Pressed metal plates (Yes I know the legal issues with these before everyone starts kicking off!:devil:) but wanted to have a clean look!
Front
Really happy with the way the car is coming on! The rear end is looking nice and fat, will be looking at getting a silver rear fog light bulb to balance up the lights and looking at spacers the same as Demi has to fill the arches a bit more. All 4 tyres will be getting replaced also for Toyo T1R's as got some cheap front tyres put at the mo and had enough of them!! Lesson learnt!
Hi, I took the power for the original cigarette lighter power feed.
Thanks, Its a standard 2012 panda so doesn't have a cig lighter, haven't checked if the 12v connector is under the centre column or if the fuse is fitted, I thought the gizmo I bought was a more direct route,
If it’s not a 169 shape I can’t help you I’m afraid not really up to speed on the newer ones
Hi, Could I ask you to cast your mind back & tell me how you got access to the battery terminals or 12v/GND supply for fitting a usb charger to that round unused vent, My USB charger came wired with an inline fuse.
I took it from the permanent positive and ground feeds for the cd player
A nice simple little mod done today to complete my interior, I got a set of Abarth pedal covers.
These just simply fit over the original pedals so no drilling is needed.
I’m super happy with the overall look of the interior now! 🇮🇹🐼💙
Today I fitted my Christmas present which was my centre console arm rest.
The arm rest comes in 2 pieces so the first job was to screw them together as per the instructions, I took the centre console out to help fitting and to give it a good clean.
The kit comes with screws for the arm rest to secure to the console but I replaced these with nuts and bolts as it felt more secure.
Overall I’m super happy with the fitment and support it gives, if you do a lot of driving I would recommend one! 💙🇮🇹🐼
My fog light replacement project is now complete and wow they look so nice and clean!!
I had to order new screws for the mounting brackets as the old ones had turned into Italian chocolate.
I also replaced the mounting bolts for stainless steel ones. Thanks to Fettle & Finesse for supplying the fog lights which they sell as a pair. 👍🏻👍🏻
I did a bit of an induction refresh on the pandavan today, I wrapped all the alloy pipes in gold reflective tape and replaced all the mismatched and old jubilee clips for nice new ones.
Overall happy with how it looks! 💙😍🐼🇮🇹
We will call this one a ‘rear end refresh’!
I got round to finally fitting my new rear blue Fiat badge, a simple enough job but it makes the car look so much less tired!
I also fitted the rear metal pressed number plate, I had one of these on the car before I sold it but it got replaced for a plastic one.
I prefer the pressed metal ones they just look less fussy.
And then the final job was to refresh the panda badge with red vinyl, I have to say it’s come out better then I thought, it will be interesting to see how long wearing it is. Anyway the final 2 pictures are the before and after, little bits done but I’m super happy how they have smartened up the rear!
I have a few jobs in the pipe line and I’m just in the process of getting all the parts together for them.
First one is to replace the air con condenser, I’ve got a new one from Autodoc I need to fit the studs to it and I may give it another coat of silver paint just to give it a bit more protection.
Second job is while I’ve got the bumper off to do the air con I want to replace the faded headlights, I managed to get my hands one a new old stock one being cleared out of a Fiat dealer I just need to find the other side now! 😂🤦🏻‍♂️
