Panda Panda 100HP project (cooperman style!)
Right thought I would start a thread as there are a few mods happening to my panda and wanted somewhere to have them all in one place! I have owned my 100HP since 2010 and love it! She gets serviced at fiat evry year and had belts and water pump replaced last year. I wanted to start modding her but not go OTT as been there and done it before! Hopefully you guys like it!
So this is what I have done:
Day one cleaned!
BMC Panel filter replaced and clear indicator bulbs front and back fitted:
Before
After
Gear leaver blue detailing done with touch up pen:
Ultersport rear 80mm back box fitted, with multi hole exhuast rubber to space it away from the bumper:
Before
After
Home made induction mod give great induction noise over 3000rpm!:D here is the link to how I made it https://www.fiatforum.com/panda/319449-100hp-induction-mod-under-30-a.html:
Before
After
New tax disc holder fitted:
Before
After
Pressed metal plates (Yes I know the legal issues with these before everyone starts kicking off!:devil:) but wanted to have a clean look!
Front
Really happy with the way the car is coming on! The rear end is looking nice and fat, will be looking at getting a silver rear fog light bulb to balance up the lights and looking at spacers the same as Demi has to fill the arches a bit more. All 4 tyres will be getting replaced also for Toyo T1R's as got some cheap front tyres put at the mo and had enough of them!! Lesson learnt!
Hi, I took the power for the original cigarette lighter power feed.
Thanks, Its a standard 2012 panda so doesn't have a cig lighter, haven't checked if the 12v connector is under the centre column or if the fuse is fitted, I thought the gizmo I bought was a more direct route,
If it’s not a 169 shape I can’t help you I’m afraid not really up to speed on the newer ones
Hi, Could I ask you to cast your mind back & tell me how you got access to the battery terminals or 12v/GND supply for fitting a usb charger to that round unused vent, My USB charger came wired with an inline fuse.
I took it from the permanent positive and ground feeds for the cd player
A nice simple little mod done today to complete my interior, I got a set of Abarth pedal covers.
These just simply fit over the original pedals so no drilling is needed.
I’m super happy with the overall look of the interior now! 🇮🇹🐼💙
Today I fitted my Christmas present which was my centre console arm rest.
The arm rest comes in 2 pieces so the first job was to screw them together as per the instructions, I took the centre console out to help fitting and to give it a good clean.
The kit comes with screws for the arm rest to secure to the console but I replaced these with nuts and bolts as it felt more secure.
Overall I’m super happy with the fitment and support it gives, if you do a lot of driving I would recommend one! 💙🇮🇹🐼
My fog light replacement project is now complete and wow they look so nice and clean!!
I had to order new screws for the mounting brackets as the old ones had turned into Italian chocolate.
I also replaced the mounting bolts for stainless steel ones. Thanks to Fettle & Finesse for supplying the fog lights which they sell as a pair. 👍🏻👍🏻
I did a bit of an induction refresh on the pandavan today, I wrapped all the alloy pipes in gold reflective tape and replaced all the mismatched and old jubilee clips for nice new ones.
Overall happy with how it looks! 💙😍🐼🇮🇹
We will call this one a ‘rear end refresh’!
I got round to finally fitting my new rear blue Fiat badge, a simple enough job but it makes the car look so much less tired!
I also fitted the rear metal pressed number plate, I had one of these on the car before I sold it but it got replaced for a plastic one.
I prefer the pressed metal ones they just look less fussy.
And then the final job was to refresh the panda badge with red vinyl, I have to say it’s come out better then I thought, it will be interesting to see how long wearing it is. Anyway the final 2 pictures are the before and after, little bits done but I’m super happy how they have smartened up the rear!
