Technical Oil pressure light after oil change - Help please!
rbd199
Uk
Hi
Oil pressure light came on after oil and filter change, any ideas / help please?
I’ve tried putting the old filter back in to see if it was the new one but seemed to make no difference!
and is any one able to help me with where the oil pressure switch is? I can’t find a image/video covering this engine anywhere
Thanks for any help!!
1.3 95 multi jet diesel 2010
Thank you, any further info would be really appreciated - It’s this type so don’t think it can go in the wrong way…
Thank you, that would be appreciated - it’s the UFI type, so don’t think you can fit them the wrong way - I didn’t see anything to be swapped onto the new filter either,
https://www.fiatforum.com/threads/oil-pressure-switch-location.331907/
Have a look at that. It says that it's on the top of the cylinder head no 9.
Any chance that you might have touched the wiring?
I don’t think so, I did spill a bit of oil when I pulled the filter out and I think some dropped onto what I think is the aircon compressor connections, or at least that’s what it looks like so wondered if it might have been something to do with that, but a sensor isn’t expensive so was just thinking of changing it just in case if it’s easy enough to get to
Is this your layout?
This is a 2007/8 in a punto
I know DPF changed a lot of the access,etc
Sorry couldnt find my filter pics (pre covid..)
Looks similar but different - see pic below, think I’ve found it (2nd pic) does that look right to you?
Despite giving the registration number, I was offered two filters for the 1.3 diesel. One was like the image and one had no valve. I bought both and returned the one with no valve.
Oil pressure switch is on the cylinder head front right. Number 9 in this EPER image.
