General Multiecuscan problem connection
Bucharest
Hi! Please a little help.
I do not know where I'm wrong but fail to connect with ELM 327 interface to my Fiat Stilo body, service, other, etc..., only on ENGINE.
I did all the tests, I installed and configured USB drivers Multiecuscan changed here and there one another but with the same results.
If I give in Multiecuscan to scan, it find only engine like the picture below and during the scan my message board loose coonection appears two or three times:
See the image scan below.
USB port settings are shown in the image below if I change something it does not connect nor ENGINE:
See the image usb below.
If I give the test it displays the following results:
COMMAND: ATZ
RESPONSE: ATZ
ELM327 v1.5 >
COMMAND: ATI
RESPONSE: ATI
ELM327 v1.5 >
COMMAND: ATE0
RESPONSE: ATE0
OK >
COMMAND: ATL0
RESPONSE: OK >
COMMAND: ATH0
RESPONSE: OK >
COMMAND: ATSPC
RESPONSE: OK >
COMMAND: ATS0
RESPONSE: OK >
COMMAND: ATCAF0
RESPONSE: OK >
COMMAND: ATCFC0
RESPONSE: OK >
COMMAND: ATCRA 7B0
RESPONSE: OK >
COMMAND: ATSH 7B0
RESPONSE: OK >
COMMAND: ATAT1
RESPONSE: OK >
COMMAND: ATST41
RESPONSE: OK >
COMMAND: ATBI
RESPONSE: OK >
This interface is compatible with ELM 327 1.4! Should connect properly with all CAN modules.
It may be a problem with the software Multiecuscan? I tried versions 1.7 and 1.5 with the same results. Mention that if I give it ok to settings the following message appears:
See the image error below.
Thanks in advance!
P.S. Sorry to admin if there is another topic like this.
