as some of you have read in my other thread (are these brake discs the same?) that I recently have had my oil changed and that my engine developed a fault straight after.
the fault is that the car, whilst driving, would suddenly lose all revs and power (causing the car to slow down cosiderably) and refuse to rev up again unless you take your foot off the accelerator then re-press. i have found that this happens most under light throttle.
I had the same problem about 18 months ago turned out to be a problem with the turbo cutting out, some sort of actuator/switch on turbo packed up, garage replaced part(s) cost £60
Also have NEVER had to top up oil between services......never had a car that used no oil at all even if was only a leak!!! it's brill
Stilo JTD 115 Dynamic 03 plate Orion Grey
