spookycinq
Right decided not to give up on the cinq! I will not be beaten! Im borrowing an ecu which is decoded & de Imobilsed & set of injectors see if any joy
Just remember to unplug the immo box if you have any, bacause the borrower will not be happy getting a coded ECU back
On a different note 3 spark plugs are dry 1s wetcompression test if it is ok leave the injector in kerosene overnight...
That's the 1 under steering column? Little Black Box?
Thinking to myself that would the earth down bottom of engine block cause the ecu to go wrong if wasn't done up tight enough? As I asked someone with small hands to do it up as couldn't get to it & then when did head gasket found was loose tightened up so now tight & having these problems
Im thinking throttle position sensor? As unplugged it & took off tb went up & down road & revs didn't die out & seemed have power back, plugged back in but not on tb wemt down raod & revs di out
