A few little jobs underway.
Stripped the pedal box assembly and gave it all a good clean of grease & dirt.
As soon as I get my sandblasting cabinet all the parts will get blasted, painted and re assembled. I am amazed at the very little signs of wear on most of the mechanical parts I have touched so far. This was clearly a low mileage vehicle that had just been left to rust.
Cleaned the steering box & idler lever, they were both covered in oil, dirt and a layer of some black gunge. Good thing is they cleaned up really well.
I need a couple of new bushes for the idler lever, and will probably change the seals & gaskets in the steering box for good measure.
Only one snag so far, I cannot remove the filling plug. It is seized solid. I have left some wd40 on it but I thing I might have to resort to drastic measures to remove it. There doesn't appear to be any wear on the steering box though.
I also decided to have ago at the rear view mirror. I took it apart, cleaned it with some light compound polish to remove the dirt and polish some of the dull patches that were caused to being exposed to the elements. Then gave it a coat of polymer polish and it now looks shiny again.
The mirrored glass could do with replacing as it has some patina (for the benefit of Peter) that I would prefer not to live with. I will have to get a piece cut when I am out on my travels.
I was also shocked to find the bulb still working. Although Tony I think you mentioned replacing yours with an LED one. Where did you get that from?
Well that's it for now, I have decided to have a rest from the bodywork for a little while. I am going to focus my attention on getting all the other components refurbished. That way, when the shell is painted I can get them fitted and not worry about the car getting damaged.
