Hmm, another suspect figure.
HP = Torque x RPM ÷ 5252...
If your max torque comes in at the same time as mine
300nm x 3594rpm ÷ 5252 = 205 bhp
If your max torque comes in at 2874RPM (as had been quoted in this thread by another member)
300nm x 2874 ÷ 5252 = 164 bhp
Now, if your car is like mine, and it gets it's power at the very top end, 5,500 rpm.. which in theory max power should be...
Move the equation; TORQUE = HP x 5252 ÷ RPM
185hp x 5252 ÷ 5500rpm = 238
If your car is dropping from 300mn down to 238 nm by the red line, then you need to seriously look at your engine. 26% drop is vast. In comparison, 3,500 to 5,500 mine drops from 243 down to 216, a 12% drop
Put another way....
Astra VXR 2.0 T (240 bhp) comes in at 320nm of torque. Are you seriously suggesting you are only shy 20 nm off a VXR? That has 55 more bhp? And don't suggest the transmission - they use the same M32 gearbox.
To cut a long story short - your figures aren't possible.
To bad I don't have my new run. I still got the old figures before they redesigned my software. This was with the old software, with power on the wheels (take a minimum of 10% up of it to get engine output):
I wasn't satisfied with the results, because they didn't want to unlease full potentional because of the cluch and gearbox. I told them there was plenty of marge left and they redone there job. They told me they chipped it now to 185BHP and 300NM. Especially in the higher RPM there is much more power. I stil have to go to them for making a new testrun, but this car has gaint more power from the first chiptuning to the second, than from original to the first.
And, just to show you, your talking nonsens, this is a run from a Bravo of a guy I know, who is on the same dyno, with the same software from the same company:
How do you mean, 185BHP and 300NM is impossible? My car is now just as quick as his.
Ow and, 320NM out of a Bravo T-jet bull**** you say? Having the same gearbox won't say it got the same gearratio. Both C544 and C530 are called M32, but are differend inside. Look at this, also completely stock, only chipped:
