Fiat driver's side footwell is wet. Water appears to be weeping from the front seat mounting / front box section area and creeping to the edge of the inner sill and floor join - a low spot.
Water leak is more apparent after driving the car. I struggle to get it to leak with a hosepipe. The water is definitely rain water.
Sills are totally dry inside when I take out the inner sill rubber grommet.
However, the chassis leg has water in it when I take the rubber floor bungs out underneath, under the front seat area.
Door seal is fine - no water passes.
Car doesn't have air con.
I thought it was the rear side window leaking and trickling down near the seatbelt pretensioner, but I've had the seatbelt area/rear window side trim out and it is all dry, even the sound deadening in the rear quarter - and I've tested with a hosepipe. Likewise the roof bar area is definitely not leaking.
Bulkhead is dry and the usual suspect drain rubbers under the bonnet are clear and working.
Rear of the car is dry, water is not travelling from the rear.
Any ideas when the water is coming from? Any ideas how water could get in the chassis leg? I am thinking that water is getting in the chassis somewhere and creeping through seams when the car is driven against rain/wind.
Any suggestions much appreciated as I'm running out of ideas!
