GeraldHales
Hi, I have a Fiat Ducato 2006 2.3 Diesel, just starting to have a problem starting. From Cold will usually start, but when warm, if I stop, I have a problem re-starting. The Engine will crank over but not fire, it does eventually start. I suspect a fuel issue. I have replaced the fuel filter so it is not that.
I have had a similar issue in the past with a Saab car, it turned out to be the relay for the fuel pump.
Does any one know where and which relay I should be looking for?
I have download a operators manual from the site, it lists all the fuse but alas nothing about the relays.
Cheers
Gerald
Cheers
Gerald
