Hello everyone. Ducato 2.3 type 250. I use 2 diagnostics (Delphi and Multiecuscan). Both report the same error. Air weight error - critical. When I replace it, the problem is the same even if I disconnect it. The temperature of the intake air is said to be 1200+ degrees Celsius. Can't even delete the error. It will appear immediately even after deletion. Does anyone know what the voltages should be on those 4 pins?
Then I have another question.
When it was cold, I went to start the cars.
This car caught badly and since then I canť start the engine and it runs on maybe 1 cylinder
. If I disconnect injectors 1,2 or 4 - or 2 of these injectors at the same time, the engine revs up. Only after disconnecting injection 3 does the engine die immediately. It smokes terribly and smells of unburnt diesel. Can anyone help? It won't be that weight. The engine ran quite decently even with it disconnected.
Video :
Video :
