How do you unscrew the steering wheel's top cover? I can't seem to find any screws...Is it from within the fuses compartment?
Hi, I have one question, Is this the connector for cruise control because i dont have any connectorse under uper cover. Only this one is free under bottom cover. Sorry for my english. Thanks
Here is a picture:
I don't seem to be able to take off the plastic bottom under the steering wheel - I have removed the small plastic cover, unscrewed the two hexagon screws which were hidden underneath, but the bottom steering wheel cover does not want to get off. I imagined it would just drop after removing the screws, but it's still holding pretty well and I guess there is a plastic pin or some other mechanical switch that I need to pull/press. Thanks for your help
This is becoming frustrating The third screw is now off, but the bottom cover still does not want to get loose. It seems holding on the top part and when I try to move or gently pull it, it does not fall. Instead the whole cover (bottom + top) is moving as if the two parts are holding together with some clips...
anybody?
